2196Views10Replies
Author Options:
how to make tachometer with 7 segment display for single cylinder 2 stroke 6v ignition..can anyone help me? Answered
i found a diy project from https://www.instructables.com/image/FU19QM5GH4NN2QX/Building-the-circuit.jpg
but i want to use only 3 led(7-segment display) instead  of  4 led..
and another problem is this circuit only fit input signal from 12v ignition 4 cylinder ( car ),
but mine is 6v single cylinder 2-stroke( motorcycle )..
what i have to modify so than i can make a circuit that can use 6v signal to the ic and only use 3 led(7-segment display..
can any give an opinion or some one that have done this to help..im not to good with electronic but i understand english. :-)
steveastrouk
steveastrouk
Best Answer 9 years ago
Changing the display is easy. Just put the three most significant digits on the circuit.
Changing the scale is also pretty easy. Play with the value of the "100+47K resistor" - make it smaller.
Steve
kill_them_now
kill_them_now
Answer 9 years ago
thanks steveastrouk..
but what do you mean by change the significant digit? the circuit in the link above use 4 piece of 7 segment led..but i want to use only 3 pieces of 7 segment led..this circuit use alrdeay pogramed ic but not pogramable ic..how i supposed to do that?
and where i suppose to add the resistor?is it ok if i want to use for 2 stroke single cylinder?i mean that is this circuit is suitable for 2 stroke cycle because this circuit are made for the car (4 stroke system?? with 4 cylinder)
i hope you can help me with a step to tho that..
steveastrouk
steveastrouk
Answer 9 years ago
The design has a thousand, a hundred, a ten and a unit display.
Omit the unit display, then you have THREE of them.
I said exactly where to CHANGE the resistor - where the 100+47K resistor is. Yes, the circuit will work for a 2 stroke, single cylinder.
Steve
kill_them_now
kill_them_now
Answer 9 years ago
ok..i think i can catch it..thanks steve..!!
can i refer again to you if i had a problem with the circuit?
steveastrouk
steveastrouk
Answer 9 years ago
No problem.
Steve
kill_them_now
kill_them_now
Answer 9 years ago
1 more steve..
the 100 + 47k that you mention is for the signal from the ic (lm2917-frequency to voltage) to the led part right? that is for changing the scale from 4 cycle to 2 cycle right?
bwhat i want to have is the signal from the igniton coil to ic (lm2917-frequency to voltage) ..the design if for 12v so how i supposed to do to change it for 6v ignition?
steveastrouk
steveastrouk
Answer 9 years ago
Yes.
Looking at the interface circuit, it should work OK for 6V ignition.
If it doesn't, change the Zener to a 6V one.
Steve
kill_them_now
kill_them_now
Answer 9 years ago
great,thanks again steve.. :-)
kill_them_now
kill_them_now
Answer 9 years ago
steve i wanna ask somthing else,if i want to use 8x2 lcd display (http://www.cytron.com.my/viewProduct.php?pcode=DS-LCD-082A&name=LCD%20%288x2%29)
instead of 7segment display,can i do that?
if yes,should i built another programable circuit to compute the voltage into character on the lcd display?or i just plugin the output from the frequency to voltage to the lcd input?
steveastrouk
steveastrouk
Answer 9 years ago
You need computing power to drive the 8X2.
You COULD display the speed on a DVM module.
Steve
