1593Views15Replies
how to measure frequency in this circuit?
i want to measure the frequency of this flasher circuit but i always get a frequency close to that of the mains. I am using a wall wart.
i changed some of the components to speed up the flashing but the frequency reading stayed the same.
to check my multimeter i tried measuring the frequency of mains and the joule thief circuit and it looks like my multimeter is good.
how should i measure the frequency in this flasher circuit?
5 years ago
Sorry to add a comment on an incredibly old thread, but
could someone please help determine how to calculate the frequency of the
flashing LED in this circuit diagram?
I would have thought it was something like
0.693*330,000*.00001 = 2.28 flashes/seconds.
But when I make this circuit in Yenka, it comes out to be
more like 1 flash/second.
There is a very similar circuit at the following website
with an explanation of how the circuit works but no timing calculations.
http://www.talkingelectronics.com/projects/FlasherCircuits/Page83FlasherCircuitsP1.html
thanks
Mark
9 years ago
How are you measuring ~60Hz then?
L
Answer 9 years ago
i measure the frequency across the LED and it always give 60Hz
Answer 9 years ago
How? You've asked how to measure frequency, but you say that you're already doing it. Do you doubt that the measurements which you get are correct?
L
9 years ago
Change to battery then measure again.
Answer 9 years ago
I'll try that.
9 years ago
Get yourself a cheap oscilloscope - you really can't do serious work without one eventually.
Answer 9 years ago
Aren't cheap and oscilloscope mutually exclusive? :-)
Although I was able to sort out my RC transmitter with a free offering using the PC sound card. Seemed to work within it's abilities. Not much bandwidth though.
Answer 9 years ago
Nah.
Around 70 USD
http://www.jyetech.com/Products/LcdScope/e062KC.php
Answer 9 years ago
Things have got better now even I could afford that.
9 years ago
Across the LED should give you a realistic reading but you can work it out.
The frequency is controlled by the capacitor and the resistor that discharges/charges it.
Answer 9 years ago
yah i know... the circuit is working...
i tried to get the frequency across the LED but i get nearly 60Hz which is impossible since the LED is not visually flashing that fast i suppose i am getting the frequency of the mains.
at some point i changed the flashing speed of the LED so i am expecting a change in the frequency reading. but the reading is still 60Hz
Answer 9 years ago
Add a smoothing capacitor - your 'dc' wall wart is spitting out bumpy dc with ripple, and your meter is detecting that ripple.
Answer 9 years ago
thanks i'll try that.
Answer 9 years ago
+1
