61Views1Replies
how to power 9 10 watt leds from a automotive battery?
I am building a under water array using 9pcs 10 watt green leds, and will be powering from a automotive battery. the led data is.
10 watt green
900 lumens
voltage dc 9-10.8
current 900mA
integrated approach 3 and 3
My current build has them in parallel due to not wanting to lose all leds if one fails but will change this if its not possible. I am having issues finding a step up dc to dc adjustable driver that will allow a output of 10.8 volts an a current of 8100mA . Anyone have ideals or a better solution. Thanks.
4 years ago
LEDs
can't be run with a constant VOLTAGE supply. They need a constant CURRENT, and ideally you would put them in series, but since 9 x 10V is 90 odd volts, you won't want to immerse it either.
You could find a 3Ohm
resistor, rated at 3W, and run EACH of them with a resistor on a 12V
supply in parallel arrangements. You will be burning an extra 30W for
your 9 LEDs.
An alternative is these very cheap regulator blocks
http://www.aliexpress.com/item/High-Quality-Specia...
These will run very nicely on EACH LED, and reduce the wasted power.
Then, as DU35M says, you need to worry about the supply requirements.
4 years ago
You need proper LED driver for this.
There is a reason why a complete LED lamp often costs a lot more than just the LED module ;)
Considering the limits of a car battery and the power requirements you won't have long running times either.
Even a proper deep cycle battery would need to be of considerable size to allow for proper run times.
The keyword here is AH - ampere hours.
But you also need a battery that is able to provide the current you need.
For example a battery with 20AH and a max current limit of 10A would only power the LED's for a bit over 2 hours a 50AH battery for around 6 hours...
Better option would be a parallel/series combination of LED's with only 4 or 6V requirements...
Of course that still requires proper drivers for these high power LED's....
