122Views11Replies
Author Options:
how to read power level of battery? Answered
hello i have battery on helicopter and i need to read power of this battery to use it in pid gain ,i read voltage using voltage divider and calculate it and i sense current before motors and calculate power, but i dont think this is working, can you help me for that?
Tags:power
mpilchfamily
mpilchfamily
Best Answer 6 years ago
How are you reading the voltage an current? Are you using a meter or an on board micro controller?
britich
britich
Answer 6 years ago
on board microcontroller
mpilchfamily
mpilchfamily
Answer 6 years ago
Yes a voltage divider can be used to read voltage. You will need a shunt resistor to read current. Reading the voltage across the resistor gives you the current.
britich
britich
Answer 6 years ago
so i put the shunt resistor with battery terminal on helicopter and thats all, wouldnt drop the voltage on motors?
mpilchfamily
mpilchfamily
Answer 6 years ago
A shunt resistor is a 1 Ohm resistors that can handle a lot of current running through it. Won't affect the motors hardly at all.
steveastrouk
steveastrouk
Answer 6 years ago
A shunt resistor is a LOW value relative to the maximum current in the circuit, you can't say its "1 Ohm", it might be 0.01 Ohm in a practical circuit.
britich
britich
6 years ago
so i must use low resistor value for shunt and low resistor for voltage divider depend on max mah
britich
britich
Answer 6 years ago
ok i want the voltage divider not to pull current so i increase its value like 68k ,33k? or i need to use mosfet?
steveastrouk
steveastrouk
Answer 6 years ago
Yes. You may then need to amplify the voltage to the range of the ADC on your processor, or you can use some of the current to voltage sensing chips that are available like the Diodes Inc (Zetex) ZXCT10XX range (there are a load of parts with 10 in front of them.
britich
britich
6 years ago
so i must use low resistor value for shunt and low resistor for voltage divider depend on max mah?
steveastrouk
steveastrouk
Answer 6 years ago
The voltage divider values aren't as critical as the shunt resistor. Make the divider resistance >10K
