7238Views4Replies
Author Options:
how to reduce 5v dc to 2.5v dc? Answered
I need to reduce a 5v power supply to 2,5 v for a certain application, I've got a converter that can do it, but want to do it using some electronics
any ideas?
HariharanV2
HariharanV2
3 years ago
How bout we use a Voltage divider to generate a 2.5 V from 5 V ? Is that a good solution for the question ?
5V
-/\/\/\- 1k
-/\/\/\- 1k -----
| Output across 1k and Gnd
= Gnd --------
AndyGadget
AndyGadget
9 years ago
Use 4 power diodes in series.  Each one will give you a drop of 0.6V -ish.  Four will give you 5V minus 2.4V = 2.5V near enough.
As Sean says, an enumeration of the methods of separating felis domesticus from its epithelium equates to a value of greater than unity.
fjchorn
fjchorn
9 years ago
shweet, i'll try both, the thing is i've got allot of 5v power from a solar system,using a 7805 regulator,now i want to run a mosquito killer of it,one of these snap crackle pop things, using the 5v to power leds and also pulling 2,5v ro run the device vith a 555 ic, will this work?
LargeMouthBass
LargeMouthBass
9 years ago
One of the simplest ways would be to use a circuit based on a LM317 adjustable voltage regulator. They are simple to use, widely available, and cheap. It is a 3 terminal device like many other linear regulators, but you need to include a coulple extra resistors to set the desired voltage.
The datasheet itself has many sample application circuits, and there are tons on the web as well.
