5157Views4Replies
Author Options:
how to repair a copper kettle? Answered
i have bought a copper kettle through ebay, but found that it has a split seam which leaks at the bottom of the spout. I cant solder it as solder is lead an not safe for consumption. Any advice would be welcome, thanks.
orotund
orotund
1 year ago
Good copper kettles are lined with a thin coating of tin on the inside. This has been standard practice for centuries. Tin is not reactive.
MichaelW32
MichaelW32
5 years ago
Use non lead solder, its mainly tin and copper...
jtobako
jtobako
11 years ago
Tin based 'sliver solder' might work. Lead based flows more easily. If there is a folded seam that has opened up you could try to tap it together. A heat safe epoxy might work, but I'd trust the lead solder more : )
lemonie
lemonie
11 years ago
A little bit of lead won't hurt you (copper isn't too healthy either). How is the spout attached to the kettle? L
