25318Views14Replies
Author Options:
how to repair hot glue gun? Answered
..because it doesn't work. the gun is hot but it doesn't squeeze out the glue anymore. the trigger is hard and 3/4 of glue stick is still in the tube.
Burf
Burf
Best Answer 10 years ago
Plug it in and let it reach its full operating temperature for a couple of minutes. Put another glue stick in and push on it with your thumb while trying to squeeze the trigger. If nothing frees up after a couple of tries, wait until it cools, take it apart and see if you can determine what is locking the trigger. If it is nothing you can fix, toss it and buy a new one. They're relatively cheap at any of the big box hardware places.
dennisg8
dennisg8
Answer 3 years ago
They are not cheap. Cheaply made. The problem is that, when anyone uses or borrows your glue gun, they don't wait the six minutes for it to heat up before squeezing. Gone through about 4 glue guns last year, and six the year before. Same issue. Never had this problem before they made them in China. There needs to be one brand that has auto shutoff, ceramic tip, and some ratchet that can't break. I am sick and tired of pushing glue stick through. It often is not practical.
KumarV10
KumarV10
4 years ago
my glue gun is not working i switched on whenots glue gun switch is on i think the fuse is fail can you tel me what to do
The StickmanS
The StickmanS
Answer 2 years ago
same problem :( i was working and for a long time i turn it on and suddenly sone smoke came out and mcb is down when i tries to plug it on it didn't work i think it is fused i will never buy chinese glue gun :)))
dennisg8
dennisg8
3 years ago
Yes, pleeze answer this rachet fix question. All these crummy rachets break in under 4 months.
sophie.t.duke
sophie.t.duke
6 years ago
how do I repair my glue gun? The trigger is loose. The spring on the inside must be off.
Karletto555
Karletto555
10 years ago
pardon the trigger works but nothing happens
frollard
frollard
Answer 10 years ago
*You can edit your question to add more information up above...
If you push the glue stick forward does it melt it?
--in that case the ratchet pawl or some part of the mechanism is toast.
If tie trigger is stiff and nothing moves, then you've tried to pull out a glue stick while it was melted and gummed up the 'cold' section of the gun - in which case it's toast.
Karletto555
Karletto555
Answer 10 years ago
how do i edit my question? thnx
frollard
frollard
Answer 10 years ago
At the top will be a button saying 'author options' and below that 'edit question' (in the right hand column)
RavingMadStudios
RavingMadStudios
Answer 10 years ago
Based on the symptoms, I'm guessing it's option B.
If that's the case, it might be repairable by carefully opening the case, removing the glue stick and any excess glue inside the case, and reassembling. This has about a 50/50 chance of working, and you'll probably lose part of the trigger assembly so that you have to push the glue sticks through with your thumb.
Grathio
Grathio
10 years ago
Wow, I had no idea you could mark your own comment as best answer.  I'll have to try that...
RavingMadStudios
RavingMadStudios
Answer 10 years ago
Whoo-Hoo!!! My Best Answer count is about to go thru the roof!! Woot!
