As rickharris and canucksgirl said regarding a valuable piece.
Home supply stores (Lowes, Home Depot, etc.) usually carry an epoxy "paint" for re-coating sinks, tubs, and other home ceramics. It's very effective, though it's only available in white (and probably not quite the shade of white of your bowl/tub/ sink...) It's not for repair, it's for covering up after the repair... ;-)
I agree with rickharris, if the item is valuable. I have done similar repairs to non-valuables by simply filling in the crack with crazy glue. The stuff has the tendency to suck into the crack and make it a little stronger.
If its in fact in pieces, versus a crack, you'll want to use the epoxy. Just go with one that does not set up quickly, otherwise it may dry before you have it properly in place.
9 years ago
9 years ago
If it may be valuable get it done professionally or you might effect the value adversely.
If it's just sentimental or ordinary then use epoxy glue.,
Answer 9 years ago
+1
