439Views3Replies
how to revive old wood?
i want to use old planks that have been exposed to the weather for +20 years. the wood has no paint and no lacquer. i tried to step on 0,5 inch plank but it crushed like a toothpick. i am quite sure the wood isn't hardwood so it is even more fragile after so many years.
should i revive it or forget about it?
Best Answer 11 years ago
It's no good structurally or probably aesthetically. Other comment(s) suggest something of a "rescue" but the wood isn't good (anymore).
L
11 years ago
Get a can of "wood hardener" in the paint section of home depot or loews or the local hardeware store. Follow the directions. It won't work a miracle but if you want to use the wood decoratively like RMS mentioned it would work for that.
11 years ago
Sounds like a bad case of dry rot. Unless you're using them for purely decorative, non-load-bearing purposes, forget it.
If they are to be purely decorative, you may be able to strengthen them a bit with polyurethane, but even then they won't take much abuse.
