1408Views5Replies
Author Options:
how to trigger a relay with audio signal (headphone)? Answered
Want output from headphone jack to power relay to turn on power amp
mpilchfamily
4 years ago
Simple clap circuit to detect and amplify an audio signal enough to trigger a transistor latch that will trigger the relay. Google Clap Circuit and Transistor latch for schematics.
gramparichmpilchfamily
Answer 4 years ago
Excellent idea EXCEPT :
If I turn off audio, it will not turn off power amp............
I need continuous relay hold until audio goes to zero db.
Thanks for suggestion,
gramps
mpilchfamilygramparich
Answer 4 years ago
The use a transistor switch not a latching switch. The point is you want to take the voltage from the Clap circuit's output and use it to turn on a transistor that will activate the relay for you. When the clap looses audio the transistor looses power and the relay flips off again.
