682Views13Replies
Author Options:
how do use i2c on arduino with out pull-up ? Answered
steveastrouk
steveastrouk
9 years ago
You're using the onboard TWI aren't you ?
act casual
act casual
Answer 9 years ago
Yes, i am.
steveastrouk
steveastrouk
Answer 9 years ago
Good. In that case, you can usually get away with the default port settings, but I recommend that you add an external pullup as well. The internal one is pretty weak.
act casual
act casual
Answer 9 years ago
how do it
steveastrouk
steveastrouk
Answer 9 years ago
External pull up ? What frequency are you intending to work at ?
act casual
act casual
Answer 9 years ago
sorry i read it wrongly
thank you
act casual
act casual
Answer 9 years ago
I'm not using picaxes I'm using arduino
rickharris
rickharris
Answer 9 years ago
Yes I know, BUT the principles are the same - This is a fairly good explanation of what it is all about.
steveastrouk
steveastrouk
9 years ago
You don't set the pull up/downs in the output mode on an AVR, you can only do it for input mode.
iceng
iceng
Answer 9 years ago
+1
Output means a pin on a digital IC like a Pic, Arduino or AVR
is FORCED High or low by an internal process and a "pull up"
is non sequitur  when compared to a Real output pin.
Of course you could be thinking of an open collector output like some
sensors that need a pull up resistor.
That does not occur ever in the land of micro-processors :-)
A
steveastrouk
steveastrouk
Answer 9 years ago
Ermm. Some of the LPC series have that very functionality - configurably
iceng
iceng
Answer 9 years ago
Didn't know that.......... Really...,  open collectors..........
Now I have to apologize to .act casual.
rickharris
rickharris
9 years ago
The pull up resistor is a passive device. In general outputs don't have a pull up they are active pins and will be high low or high impedance.
Can you explain in more detail what your trying to do - Circuit diagrams help.
