111Views9Replies
Author Options:
how to use a simple 2V LED in High voltage circuit? Answered
Hi! I have 100V 0,5A DC circuit and a simple  2V 0,02A LED, what shall I do if I want the LED to shine but not to burn it. Thanks!
steveastrouk
Best Answer 3 years ago
2W 5K resistor in series with the LED. The resistor will get warm !
Josehf Murchisonsteveastrouk
Answer 3 years ago
I would go with a three watt but you must admit that is a voltage divider circuit?
Downunder35m
3 years ago
What about quick and dirty?
3 common diodes in series will have a voltage drop of around 2.1V.
A LED in parallel to these diodes and with a 100Ohm resistor should do the trick.
All you have to do is find a spot for the three diodes where their voltage drop does not cause a problem, althoug I think less than 3V on a 100V rail is not too bad.
You still need a load on the high voltage output for it to work though.
steveastroukDownunder35m
Answer 3 years ago
What limits the diode forward current ????? You still need dropper resistors.
Downunder35msteveastrouk
Answer 3 years ago
That's what the 100Ohm resistor is for.
The LED is in parallel t the diodes, so the LED only get's around 2.1V - a 100Ohm resistor should be sufficient.
Keep in mind we are not using the full voltage, only the voltage drop along the normal diodes ;)
Answer 3 years ago
No, you have the 2.1V drop of the three diodes, but where is the limit resistor for the current in THEM ?
Answer 3 years ago
Why would I want to limit the current through the diodes?
They are in line with the output so that would be a bad thing...
IgorsS
3 years ago
Thank you all! I think I will go with the resistor to start with.
Josehf Murchison
3 years ago
Yea but you will need a step down of some kind ether a step down that uses a voltage divider or a DC to DC converter circuit whatever circuit you use don't surpass 0.02 amp.
