3472Views5Replies
Author Options:
how to use solenoid with Capacitor Discharge Technology? Answered
hello guys,
i am on a project for a pcp air gun, i want to replace the hammer that open the air valve with electronic trigger, a solenoid to strike the valve open, the travel of the valve is maximum 3mm, a weight will be added to the solenoid to help with kinetic energy.
the idea is to use capacitor discharge to activate the solenoid for a fraction of a second (to fire a burst of air propelling the pellet out of barrel)
i have seen some electronic triggers using 67v 2200uf capacitor, just to give you an idea.
now i want to control the solenoid force and duration.
can i do that with arduino? sure i need an external circuit to power the solenoid, maybe like the disposal camera flash??
Please advise.
thank you
gerarddag
gerarddag
6 years ago
about 100 lbs of force, i know the flash might work but i need to control the timing and power of the solenoid, when i press the trigger i need the solenoid to be active for 1.5ms and be able to control that time for less or more, can i control the amount of charge the capacitor get before i decide to discharge? that might control power!
thank you
MikoR
MikoR
Answer 5 years ago
What is about your project?
Jezan
Jezan
5 years ago
you mean like this? https://www.youtube.com/watch?v=CwfOdAdvY3w
gerarddag
gerarddag
6 years ago
this is a picture of an e trigger system mounted to the air gun, the solenoid use an attached weight to increase the kinetic energy,
i don't know the solenoid used so i am open for suggestions.
the basic idea is having a solenoid rated at 24v and fired at 60v for milliseconds to have more power, i need a design where i can control the time of capacitor discharge to the solenoid and maybe the charge of the capacitor.
i know it's easy to do it with/without arduino although this will be my first project and i need some guidance and advice from you guys.
Josehf Murchison
Josehf Murchison
6 years ago
What kind of pressure do you need for the air valve?
The camera flash might do it by its self.
Joe
