6078Views1Replies
how to use water soluble flux?
Hey, so i got a little Water Soluble Flux with my Soldering Gun (new to this)
Well it turns out that this stuff came with no instructions and I cant seem to find out how to correctly apply it. this is what I bought
http://www.bernzomatic.com/PRODUCTS/KITS/SOLDERKITS/tabid/252/ctl/Detail/mid/1254/xmid/6931/xmfid/3/Default.aspx
Someone please help?
8 years ago
The right type of solder for electronics work contains flux inside tiny tubes in the wire. This looks like solid solder + separate flux - not a good idea for electronic work.
If you aren't using it for electronics, then you smear a THIN layer of the flux on the two halves of the joint, heat and flow in the solder.
Steve
