Pick a bottle with a larger opening? Otherwise, a diamond grit hole saw or, if you have time, bottles and patience, a glass cutter and a few minuets to look up the instructions on cutting a hole in glass on line.
I used a carbide tip 'ceramic tile/glass' drill bit to make quick work of drilling glass. They're kind of eye-drop shaped, and cut ceramic/glass like butter.
If you really have to, the diamond saw method is easier than an oxy-fuel torch - that's a real glass blowers skill. If I were trying to fill the bottle, and I couldn't redesign to get it into the neck, I'd cut the bottle in half using a red hot wire, and then glue it back together with a UV cure glass glue - the joint would be invisible.
You'd need some practice bottles though. ;-)
You could cut a hole with an oxyfuel torch. The trick is to do it without shattering the glass. Try heating it in a really hot oven before cutting. Then after cutting, heat the whole bottle with a cool yellow flame for a while. Then put it back in the oven and turn the oven off and wait until it cools.
Really, the best way to waterproof electronics is potting in plastic. Get a silicone baking mold about the size of your throwie and then cover it with clear epoxy
11 years ago
Answer 11 years ago
11 years ago
The best way would be with a drill bit designed for glass, in a drill press, with plenty of lubricant to prevent the bit and glass from overheating.
11 years ago
In the UK, I'd get some here
http://www.maplin.co.uk/searchtemplate.asp?criteria=UV%20GLASS%20GLUE
11 years ago
If you really have to, the diamond saw method is easier than an oxy-fuel torch - that's a real glass blowers skill. If I were trying to fill the bottle, and I couldn't redesign to get it into the neck, I'd cut the bottle in half using a red hot wire, and then glue it back together with a UV cure glass glue - the joint would be invisible. You'd need some practice bottles though. ;-)
Answer 11 years ago
where do you find the glass cure???
11 years ago
You could cut a hole with an oxyfuel torch. The trick is to do it without shattering the glass. Try heating it in a really hot oven before cutting. Then after cutting, heat the whole bottle with a cool yellow flame for a while. Then put it back in the oven and turn the oven off and wait until it cools. Really, the best way to waterproof electronics is potting in plastic. Get a silicone baking mold about the size of your throwie and then cover it with clear epoxy
11 years ago
Why the side? Why not redesign around a battery which will fit down the neck?
Answer 11 years ago
ummmmm how would you do that ????? i mean like a 600mil bottle???
Answer 11 years ago
and how would it be waterproof cuase im putting water in it
