100Views13Replies
Author Options:
i am having a trimmer which i am not using can any one say me hoe to use it for electronics apllications? Answered
pleaze say me as many apllications possible example in audio side , digitalside, communication side and like wise
Tags:jetski
Quercus austrina
Quercus austrina
8 years ago
I understand what you are trying to do. The idea about skeletal sound transfer is similar to the way BoneFones work (which was pretty good, an old girlfriend let me try them back in the day) - by letting the soundwaves vibrate the bones in your body to help transmit the sound. In your case, you want to use the fact that the vibration of the teeth can cause even damaged eardrums to vibrate somewhat, and even those who have no hearing at all can feel the audio through their teeth.
To be even somewhat successful, you need to use a Frequency Modulated - Pulse Width Modulation driver. Something like this would be a decent place to start. Now, instead of the speaker on the output, you would need another driver transistor, such as a TIP31, to supply the current to make the motor spin. Once you get it to work, you will need to make sure you completely encase the motor to prevent any electrical or mechanical (as in spinning) contact with the inside of the mouth.
As with anything that works in such close contact with the human body, you must be extremely careful of what you are doing. You don't want to hurt anyone or get sued for trying to help.
Good luck,
Qa
Disclaimer: Any information in this post is purely of experimental nature. I accept NO RESPONSIBILTY for anything that anyone does with this information. That is the user's responsibility. None of the information or links given is mine. It is up to the user to determine whether or not the information given is sound, safe, or even viable.
avinash reddy
avinash reddy
Answer 8 years ago
actually it is not needed to keep on teeth but just into mouth with out touching any part but its vibration stimulates mind and thus we can here noise
lemonie
lemonie
8 years ago
What is with "jet" and "ski"?
L
AndyGadget
AndyGadget
8 years ago
Hedge trimmer?  Beard trimmer?  Lawn trimmer?  Hair trimmer?  Paper trimmer? Mr Afro Nose and Ear Hair trimmer?
Trimmer pot for audio applications? Possibly!
If it is this, it really can't do much on it's own.
Much better to decide what sort of what sort of audio device you'd like to build and then see if you can fit this trimmer into it.
How does this relate to jet skis?
avinash reddy
avinash reddy
Answer 8 years ago
actually this trimmer is having simple dc motor used for moving blade act as cutter for beard ok when we look in to the topic this simple motor is attached to a circuit like simple modulator and finally when we keep this motor by adding audio input to this circuit and keep this motor in mouth we can feel the noise which is usefull for deaf people i dont no details about it much but iam sure untill what i have said
AndyGadget
AndyGadget
Answer 8 years ago
It's hard to suggest any uses without a better description of the device.  Is it possible for you to post a picture of it and close-ups of the significant parts?
From what you've said, it might be possible to make a voice modulator (robot voice device) from it by talking down a tube with the motor part operating inside the tube.   Was it designed as an aid for the deaf, or is this something it's been adapted to do?
rickharris
rickharris
8 years ago
It could be any of these and more I guess. Especially when he tags with Jet and Ski!
avinash reddy
avinash reddy
Answer 8 years ago
iceng
iceng
8 years ago
A hair trimmer has a bunch of parts. You have to be more direct what trimmer
and what audio device you want to build ??
avinash reddy
avinash reddy
Answer 8 years ago
avinash reddy
avinash reddy
8 years ago
Kiteman
Kiteman
8 years ago
Define "trimmer".
