813Views15Replies
Author Options:
i am making a friction drive motorbike Answered
i am make a direct friction drive motorbike with a bmx bike and a 25cc weedeater i am going to mount it on a hinge and i will use a spring to tighten down the spindle. the hinge is just some angle aluminium mounted to the two bottom holes of the engine. the aluminum is just connected two a bolt that goes over the brake cross section. the spring goes from the end of the angle aluminum to the wheel axle. is that enough or do i need more?
Re-design
Re-design
Best Answer 10 years ago
I'm not sure if connecting it to "a" bolt that goes over the brake cross section is going to be strong enough. You need two attachments so it won't twist or wiggle.  Expecting the spring to keep it straight is not enough.  The springs only duty is to hold the motor against the wheel.  Grab the motor and shake it side to side.  Does it wiggle in the mounting?  If yes then it's not secure enough.
Do you have a way to remove power in an emergency?  Other than just killing the motor.  A better system than a spring would be a cable running to an extra brake handle so that you squeezed the handle and the motor goes against the wheel.  then if you get in trouble you let go of the handle and no more power.
donovanl12
donovanl12
10 years ago
no it's not, it's just missing the gun part and that's it.
BIGHAIRYDUDE
BIGHAIRYDUDE
Answer 10 years ago
it wont weld so its broken
donovanl12
donovanl12
Answer 9 years ago
nope, not broken.
BIGHAIRYDUDE
BIGHAIRYDUDE
Answer 9 years ago
but it doesn't weld at the moment you couldn't turn it on right now and start welding so it is broken
gearhead1951
gearhead1951
10 years ago
friction drive is ok , mounted in permanant contact with th' rear wheel works besr ( you MUST have a centrifugal clutch) you will need to experiment to find th' right size driving wheel to suit th' application ! i have built several and sold all i could make , FAST !
BIGHAIRYDUDE
BIGHAIRYDUDE
Answer 10 years ago
but i have saw alot of people who did this without clutches plus i dont have a clutch for the engine, why do i need one?
jtobako
jtobako
Answer 10 years ago
Because when the tire stops, so does the motor if you don't have a clutch to let the motor idle or some other way of disconnecting the two.
BIGHAIRYDUDE
BIGHAIRYDUDE
Answer 10 years ago
well i made it and it goes about 20mph but thanks anyway i just didn't know what you meant by "( you MUST have a centrifugal clutch)" i thought you meant it would bust the engine or something
lemonie
lemonie
10 years ago
Do it with a chain and sprocket, get someone to weld you a sprocket on the crankshaft if you have to.
L
BIGHAIRYDUDE
BIGHAIRYDUDE
Answer 10 years ago
thats not what i asked
lemonie
lemonie
Answer 10 years ago
Yes I know, I'm offering an alternative either for you or anyone else who might read it.
Anyway, please photograph it and publish it, I'd like to see what you build.
L
BIGHAIRYDUDE
BIGHAIRYDUDE
Answer 10 years ago
when i finish i'll let you know
donovanl12
donovanl12
Answer 10 years ago
dude i live across the street from you and i have a welder!!!!
