1620Views3Replies
Author Options:
i have a battery just say 1 volt 1000 mAh and charge it with another battery 2 volt 1000 mAh how long will it take? Answered
how many mA go from the battery to the other? how do i calculate this??
rickharris
rickharris
Best Answer 8 years ago
Depends on the battery type. You should limit the charging current or the battery will over heat
Nominally from flat around 14 hours at the recommended rate of charge. Some using an intelligent charger that monitors battery temperature or the charging rate can charge faster.
http://www.csgnetwork.com/batterychgcalc.html
ismael01
ismael01
Answer 8 years ago
lithium ion. i know the troubles with it but im doing some research.
how would i limit the current? resistor? and what should i have it set to? i see alot of cellphone chargers say 700 mA.
rickharris
rickharris
Answer 8 years ago
You need to look at the data sheet for the battery it will have recommended charging rates on it.
The Radio control world is a good place to go for fast battery charging information.
