155Views4Replies
Author Options:
i have a heating element that plugs into the wall. can i reduce the voltage and make it not as hot, if so how? Answered
SpaceShipOne
SpaceShipOne
12 years ago
There are devices called variacs that are essentially big variable transformers. They plug into the wall, and the output can be adjusted from 0 to 120V
fishing4life13
fishing4life13
Answer 12 years ago
would i be able to plug the heating element in to it? i was also thinking about using resistors, but i tried to use some, and they all started smoking. would i need a resistor rated at a higher wattage, or what? the heating element says 250 watts on it
SpaceShipOne
SpaceShipOne
Answer 12 years ago
Yes, the variac has a standard 120 outlet that is varied by the knob on top. Resistors would need to be very highly rated to withstand the current you are pulling with the heater. A variac is a better choice because you have full progressive control of the voltage
iPodGuy
iPodGuy
12 years ago
Couldn't you rig up a dimmer switch? Or the pet store has this thing called a rheostat that would work the same way.
