214Views6Replies
Author Options:
i need headers... that fit.? Answered
so my set up is, I have a 366 big block from a 2 ton grain truck. and before you say there is no such thing, it is a real motor. I have one, it is the smallest big block but its a big block. with a SM465 granny tranny and NP 205. normal headers wont fit the starter is in a weird position the starter solenoid is in the way. I need to find cheap headers that will work? do you know where I can get some? this pic was taken without the starter on. we tried to put the starter in afterwards and ya it did not work lol
NachoMahma
NachoMahma
12 years ago
. You may be able to find headers for another tall-deck BB (eg, mid-70s 427) that will work.
vince 09
vince 09
Answer 12 years ago
its not so much the motor its the style bellhousing I have. thats what I did to get the headers I have now, you know what I mean lol
NachoMahma
NachoMahma
Answer 12 years ago
. Ah. If you needed headers for a classic Mustang, I could probably help you locate them, but I haven't done much with Chevys in quite some time. I suggest searching for something like "big block" +(Chevy OR Chevrolet) +forum. Pick one that looks good and ask there.
. Hard to tell from the pics, but it looks like you only need about ¼" - do some "body work" on the header tube(s) that interfere. Not the best solution, but, with your "oddball" setup, it may turn out to be your easiest choice.
. Don't forget to install a heat shield for the starter.
vince 09
vince 09
Answer 12 years ago
sorry that I didn't put all this info in my question, but the ones that I have wont work there in no space for them inside the frame rails due to starter position. this motor was in a considerably larger rig, so there was room for all the stuff where it was but my much smaller 3/4 ton rig dose not have that room. I am thinking I will have to get fender well exit, but that is a bit expensive. or just something that will run just outside the frame rails.
NachoMahma
NachoMahma
Answer 12 years ago
. Changing the bellhousing should be reasonably cheap if the 366 has the same bolt pattern as a more popular BB. But I'm guessing you've already investigated that - if not, someone on one of the forums from my prev post should be able to help. . . What are you building? Is this going to be a show truck? Daily driver? Work horse?
vince 09
vince 09
Answer 12 years ago
I looked at that but the flyweel I have is larger than normal due to the amount of torque this thing puts out so I need that bellhousing. I was looking at getting a lakewood Blow Proof Bellhousing, kinda expensive but worth it. and its just a toy, kinda a go anywhere do anything truck lol
