457Views2Replies
i need to find a wifi antenna booster that is compatible with a Motorola dsl router?
We have a Motorola DSL Router with wifi and we are needing a booster for it. If anyone can help me that would be great.
Best Answer 11 years ago
If the router, or the computer, uses an external antenna you should also websearch on "cantenna" -- cheap directional antennas which both boost signal strength and screen out radio noise. I've used the side-firing coffee-can version quite successfully, even when I could only replace the antenna on one end of the connection.
11 years ago
Did you search this site for wifi booster? I did and to atleast 20 good hits. If they worked for them then they will work for yours.
