105Views8Replies
Author Options:
i want to connect 3m long led strips to batteries and a switch ,What kind of battery can i use and how many? Answered
Tags:led
siliconghost
siliconghost
5 years ago
I'm going to assume you are using a 12v LED strip because that is most common. If that is the case, I highly recommend one of these: http://www.amazon.com/gp/product/B007RQW5WG?psc=1&...
It is rechargeable and works fantastic. You can also use just a 9v battery but it won't last very long and won't be nearly as bright.
SanjanaN1
SanjanaN1
Answer 5 years ago
thanku..:D
Jordan Hill
Jordan Hill
5 years ago
By LED strip I presume it is 12v. You could use a lead-acid battery or even a drill battery if it is 12v. If your battery voltage is higher than 12v use a DC voltage step down converter these are pretty cheap off ebay or something.
SanjanaN1
SanjanaN1
Answer 5 years ago
can i use 8 AA batteries? will it work?
steveastrouk
steveastrouk
Answer 5 years ago
How long is this piece of string ? Generally they consume around 1A per metre @ 12V.
So, 1 metre, one set of AAs, about an hour, maybe 2
SanjanaN1
SanjanaN1
Answer 5 years ago
ohh okay..:)...i think ill stick to adapters then...:P...thanku all for your help...:D
steveastrouk
steveastrouk
5 years ago
Which strip ? How long do you want it to last ?
iceng
iceng
Answer 5 years ago
+1
What is the strip voltage ?
