1278Views4Replies
i want to control 5 common anode RGB led's with my arduino, i want them to fade throgh the color spectrum amy thoughts?
I have 5 common anode RGB led's, which i am building into a lamp setup for a present. as well as controlling them with my arduino, I would like the ability to manually adjust the color, my budget is 50 dollars, and i have 2 weeks to complete this project. i would really appreciate the help.
11 years ago
the arduino has pwm outputs on i believe 3 channels... you could hook all of the leds on a protoboard, hooked into parallel to the pwm outputs.... reply if you need help... i might have some code somewhere... or you could order 5 blinkm leds. You program these on the arduino with a gui enviroment. After you disconnect them, you can hook them up to 5volts, and they flash/blink whatever pattern that you program to do. theyre like 12 bucks a piece though....
Answer 11 years ago
alright, thanks! im going to be on the look out for some code, im not experieced enough yet with micro controllers to write code myself. i will do more research.
Answer 11 years ago
there should be some on the arduino playground.
http://arduino.cc
Answer 11 years ago
yup, its on the 'analog output' section - deadly easy. Be advised though, the arduino can't put out enough current to run all the leds in parallel - you'll need to use a transistor - which there are also circuit diagrams for that as well.
