actually i was just asking if anyone knows how to do it,i was just looking for a second opinion if what im doing on repairing a busted cdi unit,it can be repaired,ive done it lots of time,and you can use it on any kind of motorcycle,and its as good as new
not whats broken but what not working or where the busted parts is?its little bit tricky to repair,you must have the right tools to open it without doing any damage at the parts inside
The most likely busted part is the output transistor, the thing responsible for dumping the charge into the ignition coil. It'll be on the circuit board and it may well be connected to the case for heatsinking.
im sorry,but on all cases i ve encountered,the only problem with those but cdi is the the one that is called mylar capacitor,the only parts that is responsible on passing power to the ignition coil,if thatpartsgive ups you will have 0 reading of electricity,meaning that your ignition coil cuold not perform becuase the cdi failed to give him any voltage to release for the spakplugs
11 years ago
Where to start ? WHICH ignition system ?
Answer 10 years ago
the cdi on the ignition system, do you knowto repair it?
Answer 10 years ago
WHICH MOTORCYCLE. ??
HONDA, BMW, TATA, TRIUMPH
WHICH MOTORCYCLE.??
Answer 10 years ago
honda super four
Answer 10 years ago
'kay. Now, what's wrong with it ? Does the ignition coil spark if you remove the CDI input and ground the primary ?
Answer 10 years ago
yup idid the same thing you ve said its really the cdi unit
Answer 10 years ago
There aren't many things in a CDI that can go wrong - unless this is a full blown ECU. Can you get into the CDI unit ?
Answer 10 years ago
well im talking about cdi here and im asking if anyone knows how to repair it?
Answer 10 years ago
Can you open the case and see what state the circuit board is in ? ?
Steve
Answer 10 years ago
Answer 10 years ago
Well to repair it, you find out what's broken, its probably possible to fix it, if its been put together with normal parts.
Answer 10 years ago
Answer 10 years ago
Answer 10 years ago
Answer 10 years ago
If you know the answer to your own question don't ask it....
My experience differs from yours.
Answer 10 years ago
base on your expirience how did you repair your cdi unit?ill show you how i repair a cdi if you show me how,
Answer 10 years ago
im sorry for my bad english im not good at it im from phlippines.
Answer 10 years ago
you need a voltmeter to find the problem, wherever it is.
Answer 11 years ago
. Motorcycle (see keywords). <snicker>
Answer 11 years ago
ROTFL! Which motorcycle? What's the problem?
Answer 10 years ago
im having problem with my cdi on my motorcycle do you know how to repair it
Answer 11 years ago
. Anyone who is smart enough to have 314 Best Answers should be able to figure that out.
Answer 11 years ago
That sounds very similar to an insult to me.
Answer 11 years ago
. Only if you claim to be a mind reader.
Answer 11 years ago
Carnak says, "sis, boom, baa".
11 years ago
Do you know what needs the repair, or have you just got a general ignition problem?
L
Answer 10 years ago
yup!i know i have to repalaced my cdi,the problem is its too much expensive,do anyone knows how to repair it
Answer 10 years ago
Well, if it was me I'd go looking on Ebay for another CDI unit.
L
