111Views4Replies
if one of the supply wires to a hall sensor is seperated , Will it imitate the symptoms of a damaged Hall sensor?
Power supply wires to my hub motor damaged due to spinning, motor does'nt start from standstill. when it starts it works in a stuttering manner. When allowed to run without load it runs without hesitation. I read that this is one of the systoms of a failed hall sensor
Doogg1
9 years ago
If the wire's off it IS a damaged hall sensor !
Steve
9 years ago
Or a poorly designed electronic and magnetic circuit.
A
Answer 9 years ago
A out of alignment hall sensor or an iron chip can cause that.
BTW is this a multiple hall device ??
9 years ago
Sounds like it might be screwed.
