122Views4Replies
in a counter balanced system, do I need to account for both the load mass and the counter balance mass for acceleration?
I have a simple 2 pulley system lifting a 2400lb mass. Imagine a chain lift, starting at the load mass, up over a sprocket, across to a second sprocket, then down to a 3000lb counter balance mass.
to move the load down, I'll need to apply 600+ lbf down on the load. To move the load up, I'll apply <600lbf to the load. That's simple. Now, during the move I need to STOP quickly. Do I need to account for only the 600lbs difference or the 5400lbs of moving mass?
_________________
|O O|
3000lb 2400lb
counter Load
9 years ago
I am loath to do your homework for you, but I'll give you a hint; this is a simple physics problem but you are missing one element to the equation. To solve your problem, solve this: F=ma.
Don't forget what is going on with the weights at each end of the rope as it moves.
Answer 9 years ago
Homework I wish; scatter brained today would better response; but you have answered for me and honestly that is where I was leaning but couldn't prove it to myself that it was needed. But you are right; the Force = Mass x Acceleration (or change of velocity). In a steady state velocity, force applied would only be to move at a constant speed. In my question I gave the example to STOP quickly thus meaning there would be a quick change in velocity (or acceleration from velocity to zero). F=MA. Very good and thank you.
Answer 9 years ago
Sorry about that. There are a lot of students who drop in to get their homework problems solved for them and I just assumed. Anyway, I'm glad I was able to be of help.
Answer 9 years ago
:) understood. no worries; thanks again.
