18473Views3Replies
information required about "NEC D882 PNP-transistor"?
i need help and instructinos about "NEC D882 PNP-transistor" i want to use it in lamp ballast.. tell me the other equivelent transistor.... the maximum volt and current we can give to these transistors.... thanks
10 years ago
I like Datasheet Catalog. Also, go to NTE's website and download QuickCross.
10 years ago
Try a TIP29C silicon NPN transistor:
http://www.fairchildsemi.com/ds/TI/TIP29C.pdf
100 Volts for collector base and collector emitter
5 volts for emitter base
1 amp collector current (steady)
Also: might try S9014 NPN bipolar for smaller currents
50 Volts
0.1 Amp
http://www.digchip.com/datasheets/download_datasheet.php?id=846510&part-number=S9014
10 years ago
Hi, The NEC D882 appears to be an NPN device!! check out the link below to down load the data sheet.
http://www.datasheet4u.com/html/D/8/8/D882_NEC.pdf.html
Most likely many other types suitable for your project can be sought check out the spec. regards
