4182Views8Replies
install drywall board on plaster wall?
I need install drywall board onto existing plaster walls, there are no wood frames inside the plaster, inside of half to 1 inch plaster are clay blocks. can I screw the drywall board to the plaster wall without adding any additional supports? what kind of screws shoul I use for?
Best Answer 10 years ago
You can use either construction adhesive, screws, or both.
Screws: regular drywall screws. You mention that there is "no wood frames inside the plaster", there must be something the lathe and plaster is supported by. Either way, ensure you hit the lathe or the studs behind. Longer screws are probably a good idea.
Adhesive: Since you're in Canada, lepage and PL both have lines of products found in most hardware stores.
Both will work and are straightforward to install.
11 years ago
'd try gluing it with "panel adhesive" that comes in pint tubes (here in the U.S.). It has a quick tack time, and I've used it for miles of panelling. I like to make a big "X" shape across the back of the panel, and then "fill in" the resulting triangles with circles or ovals. No need to spread the glue either.
11 years ago
11 years ago
For plaster, you normally use wall-plugs, and screws to fit, like this:
www.ultimatehandyman.co.uk/F&F_WALL_PLUGS.htm
L
Answer 11 years ago
Why not just glue it on ?
Answer 11 years ago
It might work, would depend upon the surface condition of the plaster. What glue would you suggest?
L
Answer 11 years ago
PU foam. Damp the board slightly, squirt with foam, let that "free-rise" for a few minutes, but still staying sticky. Stuff board on wall and hold. If you're careful to wait beyond the foams rise time, you get great, quick results.
Answer 11 years ago
Yes, that sounds good - plenty of surface area.
L
