371Views2Replies
iphone external backup battery DIY with old nokia batteries as cells?
i wanna charge my iphone via diy backup battery made from old nokia cells or ipad battery or even couple of iphone 4 batteries
i have a step up board and a cheap backup 18650 battery board
wich one should i use and how should i connect the batteries with the battery board or without
Best Answer 6 years ago
You have two USB boards in the pic - if they are designed for 3.7V like the 18650 battery it can work.
Be aware that you need 2.0V on d+ and 2.7V on D-, otherwise your rotten fruit will only charge at a max of 100mA if at all.
Having said that using old batteries for this task is only feasable if they still hold a proper charge.
As the converter will use some energy old batteries might only give you a little top up before their voltage drops below what the converter can handle - only testing will tell.
Answer 6 years ago
thnx for the reply
as u can see in the pic there is a battery with the "charging" board and the other one is just a cell wich i discharged several times creating a spark, what kind of battery should i use just a cell or complete with failsafe boards (or whatever they`re called)
the one on top is step up input 1-5v to output 5v but i think it requires to many amps for it to be able to charge (it converts amps to volts, i think)
the one below it is the one designed to work with 3.7 18650 so i figured why not use several nokia batteries ( i can use new ones if i`m 100% sure it will work) or just buy one or two ipad battery and use that instead, i`m sure it has more then 2500mah.
as for the 2.0 and 2.7v on d+ and d- how should i solve that problem???
