77Views6Replies
Author Options:
is 470 mf close enough to replace a 500 mf cap ? Both are 25 volts Answered
Josehf Murchison
Josehf Murchison
5 years ago
FOR WHAT????
After a rectifier in a power supply, yes most likely if the output is regulated.
If it is used on the output of an amp to the speaker, most likely.
Someplace else in a circuit, No it may not be. Such as if it is used on a filter you may need to change the corresponding resistor or inductor to keep the filter in range of Its design, so it all depends on what the capacitor is used for.
seandogue
seandogue
Answer 5 years ago
+1. good point to distinguish between a localized power reservoir (caps located near to ics and loads and used to shore up the supply against momentary load current surges) and a filtration component that is designed to filter frequency components at specific cutoff frequencies.
Josehf Murchison
Josehf Murchison
Answer 5 years ago
People forget about frequencies.
A capacitor is a insulator & storage device or a resistor depending on the frequency.
An inductor is a dead short or a storage device & resistor depending on the frequencies.
470 uf is a common audio frequency capacitor.
verence
verence
5 years ago
Should work. It's close enough to try it. But make sure, the capacitors have similar ESR.
rickharris
rickharris
5 years ago
Capacitor tolerances are usually huge so will probably work - with some reservation - see josehf post.
Downunder35m
Downunder35m
5 years ago
Depends for what but usually I would say it's no problem.
