115Views1Replies
Author Options:
is PVC pipe is necessary in vande graff generator? what should be top roller and bottom roller material...? Answered
is PVC pipe is necessary in vande graff generator? what should be top roller and bottom roller material..............and if i use 6volt motor then how much voltage will produce
Kiteman
10 years ago
PVC pipe is the easiest stuff to build it from. Otherwise, use anything else that is a good insulator.
For the rollers, use materials that are as far apart as possible in the tribolectric series, such as Nylon and hard rubber.
