123Views4Replies
Author Options:
is it highly necessary to use resistors on leds. Answered
i want to do a small tiny project using only 3 led's with no resistor,now the led's are 3.3v,i only want to use 4.5v of battery power,but i was thinking of wiring it in parallel although that drains more battery power,any help would be highly appreciated thanks....
Tags:leds
iceng
Best Answer 7 years ago
OMG  the resistor goes in series with the LED.
You can go here to design an LED circuit of your own.   .   .   A
Sandeep P. Varshney
7 years ago
Yes, it is highly necessary. You can use the calculator pointed to by iceng below to get an accurate resistor value as per your need.
Jack A Lopez
7 years ago
Resistors are necessary, and good. How else are you going to control how much current flows through your LEDs?
aelias36
7 years ago
Pretty much. They're going to burn out really quickly unless you limit current.
