95Views4Replies
Author Options:
is it possible ? Answered
can  i import a router wifi signal from 7/10 of a mile away when you have to be within 100 feet to get it on a laptop without any antenna or other aid?   thanks, dsrtdwlr
Re-design
Re-design
10 years ago
Probably not unless you used a much better receiver.  The receivers in the routers and computers are not all that good.  If you picked up a "ham" type receiver that was able to be tuned in the band you are using then you might/should be able to pick up the signal from a much further distance.
Not you would still have to figure out how  to get that signal into your computer.
killerjackalope
killerjackalope
Answer 10 years ago
Interesting thought there, you could wire the HAM antenna amp direct to the antenna outputs for the receiver or before the receivers amp if you were able to work out how to remove it from the circuit.
killerjackalope
killerjackalope
10 years ago
 Yes, you'll need to make yourself a pretty decent antenna to make it happen, granted I'm hitting 500 yards using a sweetcorn can and a USB dongle...
steveastrouk
steveastrouk
10 years ago
Only way is an external antenna, something like a can-tenna might be enough.
