214Views4Replies
Author Options:
is it possible to boost my wimax speed with a bi-quad antenna Answered
is it possible to "hack" my wimax modem so I can boost the speed with a bi-quad antenna or through some other means? Here's the wimax modem type
http://imgur.com/vrsoHqW
and here's the modem opened.
[img]http://i.imgur.com/JlDAezf.jpg[/img]
Downunder35m
Downunder35m
3 years ago
First things first:
Distance?
How many devices connected to the WiFi?
Understanding!?
You can not increase speed with more or better antennas,only signal quality.
People tend to confuse this on a regular base.
With a lot of interference from machines or other signal sources a strong signal can help getting good reception and as a result high speeds as not so many errors need correcting (which would otherwise cause the connection to use a lower speed).
Quad antennas are directional so they only help to provide a narrow signal beam - everything outside this beam is lost.
I experimented quite a bit at my old place to get proper WiFi coverage on the entire property.
Name a home made antenna type and I am almost certain I tried it out already LOL
Directional ones gave distance but nothing else.
Complicated fractal antennas performed not really much better than a standard stick.
What did the trick for me was to read some actual user reviews on older modems.
I found a brand new but totally outdated TPLink TP-W8960N for just 30 bucks.
Setup as a repeater with the original modems WiFi disabled gave me exactly what I needed and much more.
With this modem I got full signal quality in my closed steel garage (workshop) which was about 40m away from the modem.
A walking test with my mobile phone showed that I got good coverage for about 50m.
Usuable coverage with minimum download speed loss for about 80m and still usuable internet after 100m.
Just saying ;)
ChickBang
ChickBang
3 years ago
Look up "ddwrt for [insert model number here]"
You may be able to install a custom firmware and then increase the output of the wireless antenna. WRT54G(VX) routers are famous for this.
dmanstan
dmanstan
3 years ago
Any help?
dmanstan
dmanstan
3 years ago
These are the pics.
