11525Views18Replies
Author Options:
is there a way to make a soft object hard (e.g. soft plastic)? Answered
some thing that you could brush on and let it harden?
lemonie
lemonie
Best Answer 11 years ago
Resin - e.g. for glass-fibre, epoxy, varnish. L
animan1
animan1
Answer 11 years ago
would it work on plastic and if so how stiff would it get? does epoxy harden fast? is it cheap? help!
lemonie
lemonie
Answer 11 years ago
Paper is soft and flexible, like glass or carbon fibres, you can stiffen these up by impregnation with resin or glue. Plastic is different, what is it that you want to make? Epoxy can harden fast, and it can be cheap depending upon how much you need. L
dbarke121856
dbarke121856
8 months ago
Is there a way to make the top of this plastic birdbath firm? The bowl bends under the weight of the water! It’s not hollow do no filler will work. I like the design and want to keep it.
KarthikS117
KarthikS117
1 year ago
I am looking for some solution to harden soft plastic made connectors.
ShahidulI
ShahidulI
6 years ago
hi i want to make a plastic box for my soft shell crab farm which will stay on salt water and under sun always.the color will be black.wel i read that pp is best for the box but i need too many boxes and also have to save money.so can someone tell me what i should do? There are 2 types of scrap pp hard and soft in the recycle market.but i dont think it will perform wel.so plz tell me what i should do?should i mix something with the low quality pp scrap ? I need the box strong and soft and last long under sun on water
animan1
animan1
11 years ago
maybe i should change it to (e.g. soft plastic) ??
Gorfram
Gorfram
Answer 11 years ago
Thanks - that helps a lot with the "snerk!!!" factor. :)
animan1
animan1
11 years ago
im tryin to make an airsoft mask and i want to cover fused plastic and make it hard.
Gorfram
Gorfram
Answer 11 years ago
It depends on which plastic you use:
Plastic #2 (High Density Polyethylene) can be formed at the temperature of boiling water, and is as readily available as the nearest plastic milk jug. Plastic #4 (Low Density Polyethylene) is essentially the same stuff as #2, and is generally fully compatible with it. They will fuse at temps ranging from 220-265 F (105 -130 C), depending on exact plastic you're using.
If Plastics #2 and/or #4 are too heavy or not tough enough, you could try Plastic #5 (Polypropylene). You'd have to get it up to around 465 F (240 C) to form/fuse it; and I don't know of anyone who's tried it, successfully or otherwise.
And Plastic #1 (PETE) should be fusible at just below 500 F (260 C), but again I don't know of anyone who's tried it.
Don't use Plastic #3 (PVC), which emits nasty toxic fumes.
Plastic #6 (polystyrene) may or may not emit nasty fumes, but is probably too brittle for your purpose anyway (or too soft, if it's in the form of styrofoam).
Good luck with your project.
orksecurity
orksecurity
Answer 11 years ago
The resins used for fiberglass might be a good choice mechanically, but probably not very lightweight.
animan1
animan1
11 years ago
no i want to make it
animan1
animan1
11 years ago
could you use it on plasic?
Z1ggy
Z1ggy
11 years ago
Glue? plaster of paris. Concrete......
animan1
animan1
Answer 11 years ago
what type of glue?? not plaster or concrete
AndyGadget
AndyGadget
Answer 11 years ago
PVA glue watered down a bit and brushed on will give paper quite a bit of stiffness.
animan1
animan1
Answer 11 years ago
it would also need to be light and could not shatter if it fell
animan1
animan1
Answer 11 years ago
what about fused plastic???? and how hard?
