1532Views2Replies
Author Options:
is there any way to remove a gear from a motor shafting? (stepper motor) without using a gear puller? Answered
jtobako
jtobako
11 years ago
Turn it down on a lathe? Careful use of pliers or screwdrivers? Make a puller? Grip the gear in a vice and gently hammer the shaft out with a small punch? Cut the gear off with a hacksaw-or cut the shaft off? What parts do you need intact? What do you have available?
insomartin
insomartin
Answer 11 years ago
i tried to remove the shafting and stator then lathed it down. the motor is small. after that i think i demagnetized the stator. i'll make a small puller instead this time. thank you!
