3530Views4Replies
Author Options:
is there any way wherein we can turn off the 5V , 3.3V or ground pin of arduino UNO through Arduino IDE software? Answered
-max-
-max-
Best Answer 6 years ago
I believe that is hard-wired to the voltage regulators on-board, the ATmega328 had no control over the power. You can use a digital output connected to a P-channel MOSFET to control the power rail (high-side switch) and a N-channel MOSFET to act as a low-side switch. If your load is very small, you could just use the digital or analog outputs directly to power things like small LEDs and such.
If the arduino could switch off it's own power, then it will kill itself because it no longer has power to turn itself back on! Like sawing off the branch you're sitting on! (It is a bit of a catch-22 situation)
pelegren
pelegren
Answer 6 years ago
thanks for the reply. I had done the control by using the I/O pin to trigger a transistor and then run a timer to turn it off so that Arduino will not consume any power while it is off. It was perfect for my application.
-max-
-max-
Answer 6 years ago
Great, I'm glad you got it all figured out!
CFCbazar_com
CFCbazar_com
11 months ago
Thanks for the reply, its very useful, but this is a mistake on the arduino side. It should be no problem to turn on the 3.3V and ground pins, as the main supply should always come from the 5V pin, which does not need to be turned off.
