16138Views12Replies
Author Options:
laptop will not start up. lights come on but hard drive won't spin and lcd stays off. Does anyone know what is wrong? Answered
Wicky
10 years ago
This could very well be what I encountered yesterday.. Try this: 1. Turn laptop off. 2. Remove power adapter. 3. Remove battery. 4. Hold down power button for 40-60 seconds.(I believe this resets the bios.) 5. Now it should start up again. This worked for me, good luck.
gmxx
10 years ago
I had a similar problem with an hp pavilion dv1000. I opened it to fix usb and Ethernet, put it back together to turn it on, booted once, and then never worked again. It sounds like a hard drive problem to me. Try burning a linux live cd (ubuntu is very user friendly, at UBUNTU.com) and booting off that cd. The live cd wont effect your hard drive, but if it is able to boot off of the cd, then the problem is with your hard drive. Hope i helped.
Sandisk1duo
10 years ago
try taking it to a shop? does the fan spin? are there any other sounds? try a new hdd
aman09Sandisk1duo
Answer 10 years ago
Fan Spins, Hard drive d0eoesn't spin, lcd doesn't turn on
Sandisk1duoaman09
Answer 10 years ago
press like 7 keys on the keyboard at one time, does it beep?
cheesemaker101
10 years ago
can you turn it off by the button or do you have to take the barrery out ? and what make and model is it ?
aman09cheesemaker101
Answer 10 years ago
I can use the button, and its an Hp Pavilion zv5000. It was given to me because the power supply was bust, so I opened it up (CAREFULLY) to fix that, After putting it together again it doesn't boot. The power lights come on , but the display stays off and the HDD doesn't spin.
cheesemaker101aman09
Answer 10 years ago
I had a problem on my laptop that sounds the same as this one so I flashed the bios and it started working again hope this helps
Plasmana
10 years ago
Are you using a mac or PC computer?
