122Views5Replies
laser cutters
hi wondering if anyone could help me have a luifure laser cutter 40w which we have just purchases software CorelDraw and laser draw 2013 came with it but the laserdraw 2013 wont load onto my daughters laptop also we did not receive a English maual with it so basically don't have a clue what we r doing any help would be greatly appreciated or we r from fmaesteg south wales so does anyone know of someone who could set it up for us thanks
4 years ago
If the software was working fine with previous versions of Windows, then you may install the software in compatibility mode and check.
-Right click on the software installation file (.exe file) and click on properties.
-Select Compatibility tab.
-Place a check mark on “Run the program in compatibility mode for:”
-Select any of the Windows versions in list where the software has worked fine.
-Press ok and continue the installation of the software.
You may also get in touch with the software vender to check if there is any version of the software that is released for Windows 8 or if there is a work around to get it working with Windows 8.
4 years ago
It looks like you have a re-badged rabbit laser. You can find the chinglish (poorly translated to English) manuals here
http://www.rabbitlaserusa.com/
Also it will only work with windows and probably not on the newer versions of windows. I run mine on XP.
4 years ago
https://www.amazon.co.uk/LuiFure-Engraving-Engrave...
does the seller have a web site? Is there an option to download the /a manual.
If you bought this from amazon in the UK find a reason to send it back and go to
http://www.justaddsharks.co.uk/about
at least you will get support for someone in the UK,.
Answer 4 years ago
+1
4 years ago
What OS is on her laptop ?
