734Views4Replies
led display using 555 timer?
can anyone help me with a design , i would like to make a 5 letter display using leds that spells my daughters name "TRULY" lighting up each letters one at a time then having them all light up at once then repeat? i am new and this will be one of my first rojects not out of a kit. any suggestions?
Best Answer 8 years ago
555 timer running lowly - 4017 decade counter to give you individual outputs for every 555 pulse LED in a box with the letter on the front to light up connected to the 4017 output
Data sheets should tell tyou everything you need to know 4017 is a very common IC.
Answer 8 years ago
thanks i just ordered some, i appreciate any info you can give me i will check the data sheets when they arrive, thanks
Answer 8 years ago
Driving leds with 4017
8 years ago
The easy, but more expensive, way is to use a microcontroller, like an Arduino. Then you can simply program the pattern in.
