495Views6Replies
Author Options:
led values Answered
All i want is a list of led voltage and current values, you would think this a simple task,not so.They are few and far between and when you do find some they all contradict.
Tags:led
iceng
iceng
Best Answer 5 years ago
Only a guideline for surface mount LEDs I like to use.
johnm56
johnm56
Answer 5 years ago
thanks just what i was after
steveastrouk
steveastrouk
5 years ago
I wouldn't think its a simple task at all, it depends on colour, process, power rating and age to name 4 parameters. Why ever would you think it was simple ?
johnm56
johnm56
Answer 5 years ago
just not as clever as you.
Wired_Mist
Wired_Mist
Answer 5 years ago
Second that !
If your looking for the Rosetta Stone of Led's, it does not Exist!
Your best bet will be a large online Electronic Components Distributor (Digi-key or Mouser)
Find the LED category and there will be a Massive list of stats that you can filter through. It may give you a better Idea
Downunder35m
Downunder35m
5 years ago
Why you think there are datasheets for electronics?
If for example all white LED's of same size and shape would be identical we would not need them.
You won't find any accurate lists, only general values depending on the color and power consumption, usually based on 12, 15 and 20mA.
Without a datasheet you can only measure the forward voltage and increase the amps till full brightness, which of course often results in premature failure due to overcurrent.
But even with the correct information I tend to feed less current to my LED's so they keep operating much longer, so I opt for extra bright LED's use them at a bit less current and still have enough brightness.
