I mean you can get some pretty good mechanical advantage just using levers, or even ratchets, or jackscrews, or...
The plans on this page http://home.fuse.net/engineering/ewb_project.htm are for homemade machines that squeeze the water out of biomass briquettes, but such a contrivance might also work for squeezing the juice out of fruit.
The old way to do it is wrap the pulp in sacking (clean of course) stack them up - Put some sturdy boards on top and insert car jack so it presses down between the frame and the pile of pulp.
7 years ago
Maybe like this? http://juicingandmore.com/index.php?topic=84.0
8 years ago
Does it have to be hydraulic?
8 years ago
try
http://books.google.co.uk/books?id=Uc8DAAAAMBAJ&pg=PA120&dq=%22cider+press%22&hl=en&sa=X&ei=ZbRhT--yOsnKhAeG9L2-CA&redir_esc=y#v=onepage&q=%22cider%20press%22&f=false
http://books.google.co.uk/books?id=YNoDAAAAMBAJ&pg=RA1-PA146&dq=%22cider+press%22&hl=en&sa=X&ei=ZbRhT--yOsnKhAeG9L2-CA&redir_esc=y#v=onepage&q=%22cider%20press%22&f=false
http://books.google.co.uk/books?id=VyYDAAAAMBAJ&pg=PA137&dq=%22cider+press%22&hl=en&sa=X&ei=ZbRhT--yOsnKhAeG9L2-CA&redir_esc=y#v=onepage&q=%22cider%20press%22&f=false
https://www.google.com/search?tbo=p&tbm=bks&q=%22cider+press%22&tbs=,bkt:m&num=10
8 years ago
8 years ago
http://www.youtube.com/watch?v=tfR1C9KJI2w
shows it pretty obvious...
2 plates separated by 4 pillars (use heavy gauge threaded rod)...
insert a hydraulic cylinder...
tada.
