176Views5Replies
Author Options:
lost wax casting: what material is the best for pouring metal into? Answered
So I made a rad Yoda wax figurine recently and I'm looking into converting him into a aluminum via the lost wax casting method. I've seen some other instructables on casting the metal into plaster of paris, but that doesn't seem to preserve the very fine details that I want. There are a few other methods I've seen on other forums, like mixing fine sand with plaster and making a ceramic mold...I have even wackier ideas like using fireproof cement, but I haven't seen anything online to support using it...what other ideas can you think of that don't involve expensive investment powders I have to buy online?
Toga_Dan
Toga_Dan
5 years ago
iirc, pro-s apply vaccum to a mold before casting. thus, there are no air pockets.
Triclaw
Triclaw
5 years ago
Wet sand ,I have used it works the finer the sand the better the cast or use clay a pottery,clay and break it off either way lost wax casting is a one time thing
Toga_Dan
Toga_Dan
Reply 5 years ago
WET sand? or oil soaked sand? ive used oil. water might cause big problems as it flashes to steam.
Toga_Dan
Toga_Dan
5 years ago
i'm amazed at the detail possible with modern injection molding(plastics)
of course, that is done at 10,000psi or more.
I once sandcast an aluminum frying pan in high school. a void was discovered in the bottom. imagine! a hole right thru the pan! but, of course, sand cant take 10,000 psi. but it is very easy to make the mold.
Yonatan24
Yonatan24
5 years ago
The only thing I've heard of is "Fire Brick".
Can't you make a rough cast, And then file it down?
