1059Views2Replies
make bench power supply Adjustable Voltage Control?
Ok so i have a atx bench power supply i made and now i need to be able to put a Adjustable Voltage Control dial on it so i can go from 0v to 12v how do i do so? And can i use any spare parts from around the house?
10 years ago
You need to convert the atx supply as you have already done, and then add another circuit to create a variable voltage. This is easy enough with an adjustable voltage regulator. It works like a 7805 or 7812 regulator but instead of just having in and regulated out, it has in, reference, and regulated adjustable out. The LM317 is a great cheap example: But be advised, it has some drawbacks. Regulating the voltage drops it from anywhere around .3v (high quality digital alternatives) to 2 volts, so the most you can regulate out of 12 volts is 0-10 adjustable.
Search for LM317 circuit to get a schematic -- there are a hundred here on instructables alone.
Answer 3 years ago
what if you use the -12 and +12 to get 24v, for a max of 22v after the drop?
however, i heard the +12v is rated different amperage than the -12v - do you know how to determine the max current draw?
