165Views4Replies
Author Options:
making a VOM into a thermometer? Answered
anybody know how to make a VOM into a thermometer??
Thanks
BTW, I made the paracord belt from instructables, many, many months ago, the belt has been the best belt I have ever owned
thanks to instructables
jack
orksecurity
orksecurity
10 years ago
Get an appropriate thermistor or similar thermosensor. Measure it under a range of known temperatures. Plot the curve. Put it into unknown temperature, take reading off the VOM, check the curve to see which temperature that reading is equivalent to. (Some higher-end VOMs come with a sensor which they are calibrated to read directly as degrees. )
jackhg
jackhg
Answer 10 years ago
thank you
NachoMahma
NachoMahma
10 years ago
.  What kind of accuracy do you need?
.  Do you want the VOM to read in degrees or can you convert from mV or ohms to degrees?
.  What temperature range are you measuring?
jackhg
jackhg
Answer 10 years ago
from 70 deg F to 100deg F it's for my kombucha, the stuff has a small temp band thanks for helping me
