1646Views8Replies
measure distance with raspberry pi?
How should i measure 10 meter distance very accurately with raspberry pi ?
if anyone knows any sensor that can measure distance of 10 meter accurately please tell me then i will manage ?
thank you.
4 years ago
Tie Pi to string, lower until it hits the ground, measure string.
You really need to be precise in your question so you can get a sensible answer.
If a mm or two is good enough then an ultra sonic module should do the job.
https://www.modmypi.com/blog/hc-sr04-ultrasonic-ra...
https://www.google.co.uk/#q=measure+distance+with+...
Research should START with google.
Answer 4 years ago
+1
Ultrasonic is one way to go, optical is another for more accuracy and increased range. But Google could have told you this I'm sure!
Answer 4 years ago
I agree with steve on this one. I've not had good luck with sonar modules. They are very easy to interfere with. Good luck with using more than one at a time, since the pings they release are not modulated. The speed of sound can vary with pressure, humidity, etc. They don't work well against surfaces that don't reflect the ping directly back towards the receiver. (that includes surfaces that absorb sound and that are angled and reflect it away.) and all of these things make the acutall data noisy, prone to random huge spikes, etc.
Answer 4 years ago
and of course an annoying trait of them is that it can take a while for the ping to return. When I wrote a basic arduino sketch to measure distance with one and print it to serial, it would update really quick with distances less than 1 foot, but as the distance got larger the code slowed WAY down, as a result of a while loop waiting for the return ping.
If you send out another ping before the last one returns, then you might get into trouble with not knowing which returning ping was which one, a problem if you have a moving object.
Answer 4 years ago
Ultrasonic isn't that precise. Variations in the speed of sound wrt temperature bugger it up.
4 years ago
Here is a product you may like...
https://www.parallax.com/product/28043
https://www.parallax.com/news/2015-01-15/new-light...
Answer 4 years ago
Still only +/- 5cm at his distance.....
The Bosch et al laser measurement devices are ACCURATE to less than 3mm....
4 years ago
Well, if you start at the top of a 10 metre building, and start a timer in the Pi, and stop it when it hits the ground...S=at^2/2...very accurate....
HOW "accurate" ? 10mm ? 1 mm, ? 1 um ?
