163Views6Replies
Author Options:
most large ( i mean VW size) transformers core rapping is what kind of metal? Answered
Found a big tramsformer, with no ID, mostly buried on the river bank.
hoping to cash in if it is cooper
RavingMadStudios
RavingMadStudios
Best Answer 11 years ago
Rapping is not metal. They are two distinctly different styles.
danelder
danelder
Answer 11 years ago
The transformer looks like any  other transformer with a metal frame around it except this thing must have had been pulled with some heavy equipment. A smaller version of it would be , in an appearance of , a pull behind generator for a jackhammer.It is buried with only one side exposed.
Open that side to see it was a transformer. Took a small sample , it looks like cooper but feels to heavy and when you drop it on concrete it tiings.
RavingMadStudios
RavingMadStudios
Answer 11 years ago
Take your sample and heat it with torch until it oxidizes - a brick-red or black scale will form on the outside. Take the oxided metal and drop it into a small bowl filled with enough saturated white vinegar & salt solution to cover the piece. Let it sit until the firescale disappears. Repeat the heating and soaking a few more times. If the solution turns blue-green, the metal is copper, or at least has a high copper content.
Burf
Burf
11 years ago
A word of caution, most of the older industrial transformers were filled with PCB (Aroclor), a highly toxic poison and a noxious environmental pollutant.  I would say that you would be well served not to try opening the steel container. The results could be disastrous.
NachoMahma
NachoMahma
Answer 11 years ago
.  Geez! PCBs are NOT "highly" toxic. They are long-lived pollutants that tend to bio-accumulate, but they are not all that toxic. Long-term and/or repeated exposure to high levels can cause problems, but short, infrequent exposure to low levels is not lethal.
.  I've (accidentally) consumed at least 2-3 tablepoons of the stuff and literally waded in it.
.  Do not burn the stuff. It produces some really nasty by-products if you don't get it hot enough.
steveastrouk
steveastrouk
11 years ago
The core is usually copper, or possibly aluminium, the shell is silicon steel.
Steve
