280Views9Replies
Author Options:
my model rockets dont seem to work all they do is smoke i made the fuel correctly but what am i doing wrong??? Answered
I make them with 20 grams potassium nitrate and 11 grams sugar but they don't work when I compact it in the pvc.
Kiteman
Kiteman
Best Answer 11 years ago
  • It may be damp (sugar and nitrates both absorb water from the air).
  • Is the fuel ground fine enough?
  • Have you constructed a nozzle?
  • It will burn faster if you compact the fuel around a mandrel - put a thin smooth dowel down the centre of the pipe and pack the fuel around it, then slide the dowel out of the rocket to leave a "tunnel" through the fuel that will increase the surface area that burns - more fuel burns, so it burns faster, producing gas faster.
(We can give more helpful answers if you include images of your problem - what does your rocket actually look like? Maybe even a video of the failed burn?)
lemonie
lemonie
11 years ago
PVC is a bad material for a rocket motor - you need to wrap tubes from paper. L
sarge89or
sarge89or
Answer 11 years ago
Actually PVC makes great rocket motors. I have been using it for years. They are even environmentally friendly as you can use them over and over.
dlbadeaux
dlbadeaux
Answer 11 years ago
in the sixties, a friend and i made a rocket out of a Srripe toothpaste tube ( without the toothpaste obviously), which flew quite well. Being old and senile, I can't recall how high it went.
lemonie
lemonie
Answer 11 years ago
I guess it depends upon the fuel, but PVC is more dense than paper / card (usually) - heavier. Fuels I was thinking of would burn it, but I'm probably thinking of something different. L
sarge89or
sarge89or
Answer 11 years ago
I have used rocket candy (sugar + KNO3) and black powder fuels. For most model rockets the short amount of time for the burn does not melt the PVC and the ability to reuse the tube vs. weight difference makes up for the small difference in weight. Plus the PVC is stronger than the paper tubes.
lemonie
lemonie
Answer 11 years ago
I was thinking of the chlorate mixtures I've used, which aren't the same (still working on something that gets off the ground...) L
sarge89or
sarge89or
Answer 11 years ago
Chlorates are very dangerous and not recommended for use in model rocketry nor in making fireworks. Chlorate fuels have spontaneously ignited on their own. Good way to seriously injure someone or destroy your home or garage. Please be very careful. You can make model rockets that do not violate FAA or other federal laws, but will soar to great heights with safer fuels like rocket candy and black powder.
lemonie
lemonie
Answer 11 years ago
Yes, I know this from experience... L
