269Views11Replies
Author Options:
my rock tumbler borke can someone tell me were to get the part or what i can use to replace it Answered
the first one shows the driveshaft with the thingy that was on it that helped it spin the 2nd one is the thingy that helped it spin?
PhilP1974
PhilP1974
10 years ago
I can't tell what make your rock tumbler is from your pics, but Buy Rock Tumblers Online has a range of spare parts, so you may be able to find what you're looking for there.  There is also a big range of great value, high-quality rock tumblers there if you don't manage to fix yours.
Good luck!
lemonie
lemonie
10 years ago
Having read other comments: can't you fix it with tape?
L
lemonie
lemonie
Answer 10 years ago
Oh dear. Car-body-filler? (it's a styrene-based plastic) or "JB Weld" L
cerberustugowar
cerberustugowar
10 years ago
It looks like one of those childrens rock tumblers that arn't really built to last but maybe if you triple up or however many times a rubber band around it. Or maybe a couple o-rings If you are looking at tumbling lots I would check out the ones made by Lortone. I have 3 of them and they are ment to run, you can get parts for them and are simple. cheers
Don,t try this at home
Answer 10 years ago
thanks and i got half way done with my german dark al powder and it broke lol
orksecurity
orksecurity
10 years ago
.... Can't tell from the picture, but it looks like it's just a piece of rubber tubing that was press-fit over the motor shaft so it would have better friction against the drum...?
orksecurity
orksecurity
Answer 10 years ago
Try the hardware store. Try a pet-supply store. And, yes, Lemonie's suggestion of using friction tape (which is available at the hardware store) would probably work at least temporarily.
frollard
frollard
Answer 10 years ago
Seconded...surgical tubing would be a great friction fit. Simply clean the post, wet the tubing, and slide it over the shaft, let it dry, fixed :D
