107Views2Replies
Author Options:
need help with my esc and tq colaberation ? Answered
Thanks for your time,I have a question?i had just bought a 69 monster traxxas rc camaro .For a whole day i was having fun cruising ..The next day i unpluged the batteries from charger.Plugged the batteries to the car, And my esc went up in smoke...now i have a 320a brush brushed esc with no buttons and the reciever'"has no buttons for binding the esc has no buttons..Now how do i connect all three things?I wAs thinking since the reciever is al ready binded with my transmiter because i bought it that way ,,how do i do the 320a esc And i was wondering how many volts or what kind of power and how much do i use to power up a reciever and can i use transmitter and recievr with out esc
rickharris
rickharris
6 years ago
You need to locate and cure the problem that broke the ESC in the first place or it will happen again.
Your receiver should be fed from a BEC either built into the ESC or seperate - No more then 5 volts.
Your ESC is fed from the receiver - signal - and from the battery - Power.
rickharris
rickharris
6 years ago
Your ESC should have come with a data sheet explaining how to calibrate - IF not look up the maker and see if they have a web site with the information on it.
Generally you - Set throttle to 0 - Attach battery to ESC - ESC bleeps - Set throttle to 100% ESC bleeps again - Set throttle to 0 ESC bleeps several times - Calibrated.
